does anybody know why my light is coming on? It only comes on when the tractor is warm and when I am idling under 1200 RPM's. It's not low on fluid and the transmission shifts fine and the tranny doesn't make any noises
It is also possible that depending on the trans oil/hydraulic oil used, if it has quite a few hours on it its possible its sheered down some so its reacts as a lower viscosity oil when hot. If as the previous post mentioned that the pressure is within reasonable limits and you think all is ok, wouldn't hurt to change that oil and filter as that can only help, can't hurt.
Discussion Starter · #5 · (Edited)
If the sending unit was bad I would think the light would be eratic. the light is like clockwork. once the tractor is warm and idling below 1200 rpm's the light comes on. thanks for all the advice though. I will try all your ideas
