If you had that message, that is not good news. Take the moisture tester out of
the hopper and take it apart on the bench and clean and inspect.
Maybe it was just stopped up with some bad wet grain.
Every time you put the key to on, to start the machine you should hear the tester go
through a cycle.
The newer 70 series had an improved tester with rubber
gasket, etc.
