1 - 2 of 2 Posts
I have a 9600 combine that I am adding the GreenStar harness so that I can start field mapping. I am running into an issue with the harness on the inside of the cab where you attach to the armrest. The armrest has a 9 pin connecter, and the GreenStar harness I got from our John Deere dealership has a 6 pin connector. So there is no way to attach the two. According to our dealership there is only one GreenStar harness for the 9600 combines. So I can't get a different harness and they can't find an adapter that will convert from the 9 pin to the 6 pin. Our dealership is saying that they will just come out and rewire the 9 pin end into a 6 pin, but I have concerns about that not working properly.
Some additional information is that our dealership was able to find a serial number break that shows a conversion from the 6 pin armrest adapter to the 9 pin after serial number 660000. I'm lucky enough to have a 9600 after that break, but not lucky enough to be able to find an adapter to make this GreenStar system work.
Questions:
Does anyone else have experience with this issue?
Does anyone know if there is an adapter out there to resolve this problem?
Do you know where I might go to find one?
Thanks in advance for any advice!
Discussion Starter · #2 ·
I got the answer from another forum, but I'm going to post it here for the next guy:
If you are above 660000, You do not use that, coil it up behind the seat. see below straight from the instructions
25. (9400, 9500, 9600, and CTS combines Serial No. —
660000) Route 6-pin rectangular T-connector through
access hole (A) in bottom of right rear corner of seat
console.
660000— ) (9410, 9510, 9610, and CTS II combines)
Roll up 6-pin rectangular T-connector and store inside (-------
26. (9400, 9500, 9600, and CTS combines Serial No. —
660000) Disconnect 6-pin connector (B) at top rear of
armrest console.
1 - 2 of 2 Posts
