I am having trouble adjusting my concave. The actuator earlier this spring would open the concave, but not close it. Bought a new $737.00 actuator and that wasn't the problem. Checked the voltage on both wires feeding the actuator. Both are putting out 13.35 volts. Had the motor on the old actuator checked out and it is fine. Tried wiring around the connector for the wires. The connector is just fine. I made sure the concave is freed up. it moves very easily. After messing with it the other day it will now close but not open. Just the opposite of what it had done all spring. When someone was in the cab pushing the switch to open, I could hear the motor start to move, but would fail repeatedly. Do I have a ground problem? Do I need a new switch? I am about ready to pull my hair out from frustration. It is all I have left to do before wheat harvest and I plan to start later this week.
Thanks for all help.
