Hi all.
Firstly my apologies for my first post being a request.
I am in the process of swapping engines on an oldish 9600. Coming out is a 6076HH001, and is being replaced with a 6076HH030.
Apart from the difference in the block re water and the timing casse treatment, all of which were easily sorted, I now have the problem with the motor simply not wanting to play.. It is running very ragged, the throttle switch not working and the motor not shutting down when the key is turned off.
I have been through the wiring, and noted it is identical, as well as noting as far as I can see, the injector pump is also identical.
The only thing that I can see that has changed is the tacho sensor. It is also noted that according to the piller readout, the motor is doing 3000rpm when it is idling. Am I on the right track with my problems being due to a different tacho sensor reading and if so, how can this be rectified.
Thank you in advance.
