I was wondering if anyone knows how to get the returns auger out, the one above the cylinder, the bearing or bushing is out and it looks like a bugger to remove. Thanks in advance
It's been awhile since i did it. There is a slot cut in the auger tube under the the bearing flange on the left side to rotate the auger out though that. I think you just loosen the right bearing flange and turn auger till u can access it through the return hole over the cylinder. Like I said been 5 or more years since I changed one. I don't think you have to take the sprocket off either just the chain.
take off bottom housing of return elevator, remove bearing flange on lh side, move ladder forward and twist out. simple, you can do it in less than an hour. in and out
