9600 john deere wont shut off when the key is turned off all the time. stays at the acc setting, with the alarm panel lights on, but no cab fan, and the lift pump running. Checked all the plugs in the harnesses for corrosion and dust and cleaned them. still same issue. Anyine have this problem and what were the fixes?
It must just be itching to keep going!!!!
I haven't been around a 9600 so this is just a guess based on how my Gleaner works. Next time it happens, check for voltage at the fuel shut off on the injection pump. If no power then maybe the fuel shut off solenoid is sticking open? If the engine is running then the alternator could still be producing current for the "accessory" items. The cab fan would likely get power from a relay that shuts off with the key.
Check the 2 big relays on the left side of the battery maybe there's one that stuck close even if then the key is shut-off
