This will be our first season to harvest with a JD combine, so we are a little new to some of the features and troubleshooting, thus I am asking for some help. We have gone over the machine and heads this past summer with a fine tooth comb and corrected any item that we found. This Saturday we attached the 930F platform to the machine to test that everything was functioning properly. All sensors will calibrate correctly, Contour Master functions correctly, reel up/down is OK...BUT...we believe we are having a problem with the Fore/Aft control for the reel.
The first 3 to 4 times I cycled the reel in/out, it appeared that it was OK, except that retract speed was about 1/2 that of the extend speed. About the fifth time and it would extend, but not retract. I cycled the button back and forth in the cab a couple times and it finally (slowly) retracted. At first my dad thought it might be binding, so he greased the slides, but it made no difference. I should note that when it does slide it moves evenly and appears free-moving.
Repeated attempts had the same results: extend no problem, retract would generally not work, but after multiple attempts it would retract slowly. I noticed the fore/aft hydraulic lines seemed to flex like they were under high pressure relative to the other lines which didn't appear to flex at all. I thought the hydraulic couplers might not be engaged well, so I closed the valves, re-coupled both sides, and re-opened valves. Same results.
One thing I noticed was that the couplers were tight, even at rest, like they had some pressure on them. This was different than the other connections. We even moved the reel to the mid position and you could still sense that both lines were somewhat tight with pressure. Even switching the valves from open to close for the fore/aft lines was more difficult. The other valves would open/close with ease.
If someone has some experience or pointers...it would be greatly appreciated as bean harvest will start for us in about 2 weeks.
Planterman
