I have a 9650sts that is having an electrical problems, everything is working but the ac fan and the seat pump. I have checked the relay behind the buddy seat and I am getting power to it and it clicks when you flip the switch. looking for a little advice if anyone has fixed this issue before.
Both Seat pump & A/C fan get power from the F1 50A breaker & K1 HVAC relay in the engine compartment Relay panel. If there is power there, trace wire 17 forward to the cab.
I have went to the back and found a loose connection on the relay. fixed the issue everything is working like it should now. thanks alot!
