Having problems adjusting variable header drive to speed i want. If it is on slow and you speed it up it goes way to far. Ive had better luck speeding it up all the way then tapping button to slow it down to the speed i want.
It is the regular duty drive on 693 head so no problems slipping or getting hot. also was switched to single point header hookup by previous owner. It almost seems like valve is sticking open for a little after you release the button. Or did they forget to put an orifice in somewhere? Also loses speed slowly throughout the day. not sure if that is related or not. thanks.
