1 - 2 of 2 Posts
dad and i are going to look at a 9660 in the morning that we're considering buying.
a friend who used to work at a deere dealership said there is a sequence of buttons you can hit on the corner post to see if there are any stored codes in the computer.
does anybody know what that sequence is??
we're leaving around 5 in the morning, and i'll check this before we leave if anybody has any info.
thanks,
Ryan
- turn the key switch to the run posotion
-press the dia switch on the corner display
-scroll up or down(select controller)
-press enter
-push the scroll up switch once if code is there it will say codE
in not htere it will say nonE
-IF code it there press the enter button
-record codes and contact your dealer or some of this info will be in the owners manaul
-most of my customer call, i guess calling is a little easier
1 - 2 of 2 Posts
