As I was finishing beans last fall, the automatic header height control started to act up. It would start bouncing like a pogo stick. If I stopped, it would settle down, and be OK for a while. I tried the sensitivity dial to no avail. I am open to suggestions as to what the problem might be.
I think there are two oil flow adjustment bolts at the hydraulic stack located on combine right side. They are to be set differently depending on which header is being used (flex, platform or cornhead. Instructions should be in both owner's manual or header book.
