A buddy of mine has a 9750 that will not run. It started out as,"the fuel filters are plugged". Changed filters,helped for a little bit. Then they said the filter in the bottom of the tank,is plugged. So we drained 200 gallon of fuel.Cleaned the filter in the tank above the pit ****. Still no better. Shelling through the field,dies,then starts right up. Will die on every through in 1/4 mile field. Now it dies just driving it in the field ,even when it is not under load. Deere cant find it.I told him you guys might be able to help.
Thanks,
Illinois Gleaner
Thanks,
Illinois Gleaner
