i just bought a 930f and it has the auto header height controls. what i am wondering, is if the header has auto header height, will it allow the contour master to be automatic as well?
it depends of if the header has a sensor on both sides of the header it should be right next to the wobble box and on the other side on the end of the poly sheet
If you are in the flex position cutting it will. If you are using it in the ridged position the head will need the auto height sensor rods for it to work.
