I'm getting error code ER91 while calibrating 625F header on 9760
code er91 is center sensor which 625 does not have, at first I was getting er81 right sensor bellow .5V, played with wires and adjusted sensor linkage
er81 disappeared now its er91. Someone have solution?
On the rod that runs the length of the head, that DoubleJ mentioned, make sure all the "levers" on that rod are equal distance from the cutterbar supports. If not just tweak them till they are all the same. Hard to explain but if one is touching, that's enough to put the sensor out of range. Dave
I had a short in one wire inside the loom where they hang under the top frame, right hand side below the hazard light. It caused all sorts of low voltage problems in both flex and rigid mode
