Will a 9760 adequately carry and push a 12 row head? We currently have a 9660 but are considering up sizing, in order to run a 35' flex. I assume a 97 will do all the above, what about lift cylinders? I've heard some using dual lift cylinders, is this only on the newer chopping heads? My first instinct says that a 97 will work on both setup's fine. Although if we do not up size I do not think a 96 will do both, I think one needs the added HP of the 97. Thoughts?
Thanks
B
Thanks
B
