Re: 9770 4WD
I seen this some time ago and finally found it, hope this helps.
Number: 79373
Solution Summary: Can the Four-Wheel Drive Motors Be Swapped from a 60 Series Combine to a 70 Series Combine?
Publication Date: Jan 18 2008
**Paper copies of solutions may not be the most current solutions**
Complaint or Symptom :
Customer has traded in a 60 Series combine for a 70 Series combine and would like to move the four-wheel drive motors to the 70 Series machine. Can this be done?
Problem or Situation :
There is no information in the Ag Sales Manual that talks about this conversion.
Solution :
Four-wheel drive bundles, BH90115 and BH90116, can be transferred to 70 Series machines with a few additional parts.
Quantity
Part Number
Description
1
AH220122
70 Series 4WD Harness
1
AH226745
Case drain hose (Replaces AH153932)
1
AH225307
Forward pressure hydro hose (9670–9870 Only)
The following cab address will need to be changed to show that the Four-wheel drive option is install. , CAB 113 - _ X X X X n X X DISPLAY/MODIFY: Four wheel drive option 0 = Disabled 1 = Enabled
Instruction, H206890, can be downloaded from the Field Installation Instruction website for assistance with hose routing.
Additional Information :
The parts listed above are now included in bundles, BH90115 and BH90116.
9770STS, 9570STS, 9560iSTS, S690, S560, 9660STS, 9860STS, 9670STS, 9880STS, 9760STS, 9870STS, 9880HM, 9560STS
REAR, POWER, MOTOR, ASSIST, PTS, AH226745, AH153932, H206890, AH228793, AH225307, BH90115, BH90116, COMB PT, 5956, 5955
