1 - 10 of 10 Posts
Im looking at a 9770 thats coming up at an auction. It has the fixed speed feeder house, and im not sure if that will work for us or not? We cut mostly 30-40 bu wheat, 25-30 canola as well as peas and lentils, everything straight cut. Will hopefully be pushing a 35-40 ft macdon flexdraper. We have had red combines for quite a while now but trying to add a green one to see if we can get some better dealer support. It only has 570 sep hrs but anything special to look for would be appreciated, thanks!
Yes it will work for those crops just fine. You never change backshaft speeds while using a small grains head.
The variable speed is needed to change when using a corn head and even then you can manage successfully using a corn head without the VS as well.
Let us know if you get the machine.
Make sure it does not have a level land feeder house.
Oh okay you are referring to contour master. We didn't have that on either 7120 but our 7230 does. Only time i've used it is to get through gates easier. I could see with deere heads it'd be a must but with the macdons great float system I'm not sure it would be a deal breaker for me....
There are two fixed speed feeder house options, standard and high capacity. The standard setup uses single D belts for both the upper and lower drive which I think is totally inadequate for a class 7 combine unless you are just running a pickup head in mediocre crops. Deere should've left this setup behind with the 9610. The high capacity setup uses a 2C belt setup, same as the high torque drive. This is the one you want.
1 - 10 of 10 Posts
