Going through the 9770 at the moment. What sought of issues have people been finding on these machines? This one has done 1650 rotor hrs.
We go through the machines ourselves now after catching dealer out numerous times replacing unworn items. have a mate that use to work on sts's look over it.
so far we have done the throat elevator chain and top sprockets. reversed feed accelerator strips, reel pump brgs as they were knacked. welded up rotor gearbox frame and braced. replaced cge elevator chain and top sprocket. done all brgs on augers under rotor. anything else other people would recommend looking at?
There's a pressure sensor valve on the valve bank LHS of machine. It monitors rotor pressure, the resin perishes. Gave way on me last harvest, apparently common. Was unable to maintain rotor speed. Tell tale is hyd oil weep around valve stack.
