Does anyone else have problems with the inner dual rim cracking by the valve stem and have you found a fix for it
Yes , both inners on my 9870 have done the same. 40ft header and hopper ext probably doesn’t help . Removed the rims and broke the bead on the valve stem side and removed the stem . Drilled end of crack the prepped the crack with grinder and welded them up . Used a file and Dremel to clean up stem hole , put a little silicone on stem and installed it . Guess I’ll find out if it fixes it after harvest this year. New rims at jd $3500 each and they sold 7 last year alone! Combine is new to me so don’t know how long it has been like that, took about 2 weeks for them to lose air tho.
Yes it is a problem on some of the STS models, best way to fix we found was to weld the hole shut and make new stem hole on flat part of rim.
Discussion Starter #4
my tire shop wont mess with rims welded of any sort since a local guy was killed after a welded rim let go . i take them up to rimex in saskatoon and get a new ring welded to the hub
