Combining barley I noticed a small banging sound, like metal on metal. My first though was it was a belt hitting somewhere but after some more use I concluded that it was too abrupt, thus I decided it was metal on metal!
It would get worse in laid down crop, and through the day progressively got even worse. Its not constant, every little while there is a bang.
At the end of the day it was getting really bad, so I figured I'd make one straight run down the middle of the field where it was standing very nicely. The sound got even worse, and now it makes it when its running empty.
So took the header off, and this morning I've rotated the beater and the feeder chain and found nothing that was bent/broken/loose. It sounds like its coming from directly under the cab but its really hard to tell, maybe a bit to the left.
Anyone have any ideas what this might be? I am now going to inspect the rotor and make sure everything is cool there. All the chains and belts are in spec so its not a bad adjustment.
