1 - 13 of 13 Posts
Moving up into a 98 r62 from a 93 r52 and looking for advice on rotor setup. It has 8 bar open spoke rotor and all forward bars. I know people get all upset at reverse bars but we had them on the CDF and the open spoke on our 52. Looking for what you all have and also is there a need for filler bars in a 62 for wheat. We had the original rotor in our 52 and use to run filler bars and when we went to CDF didn’t seem to need them. Tia for all the help
Do you think having an enclosed rotor in your R52 worked the grain a little more while on the threshing side than it did with your open rotor? I'm thinking you'd be getting more grain on grain threshing action with the cdf that the open rotor would. I'll bet the same would hold true on an R62.
I know different types and varieties of wheat can have very different threshing issues a guy has to contend with. Here, I grow soft white winter wheat and there's not many threshing issues. However, I do have a preferred variety that's prone to carrying a lot of white caps. That's when I start adding filler bars to the concave. This is on an R50, open rotor, with f2 concave bars on the separator side and two reverse bars for wheat on the discharge end. Guess I can't imagine the reverse bars doing a lot for threshing at that stage of the process, more useful at shaking grain out of the straw mat.
Discussion Starter #3
The CDF helped on green stem beans and was able to not run filler bars in wheat any more. Corn was a toss up. We had the 8 bar dialed in on the narrow body machine. Looking for recommendations on the 62 setup for harvesting these three crops.
I'm just lurking around to learn, I dont have and experience with rotor mods. When yall say filler bars, are yall referring to filler bars on the concave or filler bars between the rasp bars on the open spoke rotor to make it behave more like an enclosed rotor? Thanks in advance
High angle helical bars. Stops the overlap and high wear on the left side of the concave. Better separation and less power requirement.
You'll wonder why you didn't do it sooner.
Discussion Starter #7
What about extending the rotor bars into discharge area on 4 of the 8?
Talking about filler bars put between the bars or slats of the concave. I start at the first one from the feed opening and work my way back.
Discussion Starter #10
A 98 R62 should already have to long cylinder bar on the left end of the rotor. Or am I missing what you are asking?
It didn’t look like it did from just looking at the bars when we were looking it over. I will inspect closer and let you know. Thanks
First off, what are your crops? I run a R62 open rotor with many mods and have tried a few different things with the rotor. Next year will be a new mod due to unthrashed spring wheat the past two years. I posted a few years ago my rotor mods, you can look them up, only difference now is I only run 4 sets of bars in the thresher side.
Discussion Starter #12
CORN, SRW WHEAT AND BEANS ONLY CROPS. Do raise double crop beans which we do have green stems at times
Couple things I have been told via here and ag talk.
extend rotor bars into the discharge area and remove every other paddle.
run a reverse bar on rightside and one in the second row 180 out from one on first row
place at least 3 filler bars in and can leave in for all crops
one guy even takes every other row off entire rotor for all crops and claims it works better than having 8 bars
Discussion Starter #13
I checked on it and it was a few hundred on serial of having them. All forward bars installed and they end at the paddles.
1 - 13 of 13 Posts
