Yesterday the feeder house raise and lower goes haywire, jumps up and down and then stops responding altogether. Finish the day at fixed header height. I was able to manually raise and lower the header by depressing the solenoid plungers under the cap that secures the coils. Today after checking for voltage at the connectors it appears there is a signal but only for a second. I was able to cycle the raise lower valve with an external 12 volt jumper so I know the hydraulic system is working correctly.
