9870 en detail/ pictures
2052 Views 18 Replies 9 Participants Last post by  kansasfarmer09
last fall i had the chance to run a 9870 for a day
i took some pictures for the forum
and finally here they are
startup
hope you enjoy to see some details
1 - 19 of 19 Posts
Re: 9870 in detail/ pictures
Great photography, twitter. Thanks for the perspective!
Nice pics, how was the accuracy of the moisture meter?
we tested it it and found it fairly good as far as i can remember
with the new model they have fixed the moisture curve so that it one thing
you can't cange anymore
but you can still put in a cal number
we had some problems with the
the sample rate of the moisture meter
since this is fixed now as well (if i remember right)
so it ended up that the motor stalled 2 or 3 times
i think this problem is fixed now
we have one on the lot I can get pictures of.... but what pictures I've ready shown have shown everything as does the ones above, any others wanted?
some pics of random changes
this was a very good idea and helps to lift the auger
some changes that where used from the
premium
Quote:Cool pics!
Does anyone have a close-up of the Hydro. lever?
-Christian
Christianh is this ok, it's not a close-up.http://img408.imageshack.us/my.php?image=naarmrestwith4wdtt2.jpg
-Christian
thanks
i think they did'nt change anything on the lever
what are you looking for??
Is that small screen on the arm rest a touch screen or do you use the buttons? Ours won't be here until mid July and I don't have the lit handy.
I don't believe it is, but I could be wrong. They should make it an option of mounting either there, or removable so the GS2 touchscreen display can be displayed since they overlap each other's functions, and thus up out of the way and touch screen.
Just an idea....
Nice pictures!
I've always wondered, how long does it take for the systems to boot up after turning the key?
-Christian
Quote:Great photography, twitter. Thanks for the perspective!
thanks, always nice to add something to this forum
here some more pictures
display menu
-Christian
thanks
well i think it took about 20-30 sec for the display maybe a bit more
but i had to take 2 pics to catch all the control leds
Quote:Is that small screen on the arm rest a touch screen or do you use the buttons? Ours won't be here until mid July and I don't have the lit handy.
No not a touch screen. I see their still using that same crappy mount for the GS2 display. They could mount it so it was in a more inconvenient viewing location but that would be quite a struggle.
Don
Don, here's what we did for mounting. The OEM mount was a little pricey, so we just whipped up one that mounts on the old GS1 location. Use all three screws! It's a little out of the way, but it's not too much trouble to use the touch screen.
The problem is the screen is large and the border around the screen is wide making mounting in the current cab tricky, to not block view or make convenient to see.
Don
we have mounted the gs2 in the right corner right under the headliner
the problem with the mounting area like coll. boy has shown is that i is very limiting
for the view around corners when traveling on streets
wow seeing these pictures i cant wait till we get our 9870sts, good pictures man
1 - 19 of 19 Posts
