Anyone using a 9880 for air seeded? Is the linkage for the hydralics adjustable?
I have a very hard time holding the lever for the hyd fan in the proper position to allow the hydralics to run the fan properly. It seems that the lock is not quite set properly or else the cable needs adjusting.
Have only been in yard with tractor so have not had a chance to warm hydralics up completely. Will this make a difference in the way the the lever sets the outlet???
Any help will be appreciated.
Thanks
Do you have the fan conected to the right-side remote? There is an adjustment for the detent that may not be set right. You should not have to hold the lever, it should stay locked on.
It should stay in place, and it really shouldn't make a difference if the hydraulics are warm or not.
Discussion Starter #4
I think you are correct when saying that the detent is not set properly. I talked with two long time mechanics yesterday and they both said to turn up the detent on the remote to get it to stay in postion. I am going to give it a try today.
