Last year was our first with a 9760 STS. It has large wire with inserts in the first two openings. We bale all the staw so we like to cut it low in the float position. Also it has a 30' head. The problem was that we were running alot of loose wheat over and ended up running about 1.5 mph to do a good job. I know it is alot of material going through at once but we hate to cut it high and then come back and cut again with the haybine.
The question is do you think it would help to put in the small wire concave? My next question is then if we do put in the small wire and run that much material through will it make the staw even smaller (which we don't want to happen)?
My thoughts are to go down to a 20' cut so less material but then I might need the small wire to get the heads claened out real well.
Hope you can see where I am coming from and can lead in the right direction. Thanks
P.S. Doing more wheat this year and also some custom work and want to speed it up some and do a good job for them also.
