1 - 16 of 16 Posts
You could add one at one time , they had kits but a couple years ago i asked and they quit doing the kits. So you can do it but you need to buy everything on its own and then it gets crazy in price. If you have rocks my advice would be switch combines even brands, a rock in a 9090 cost me $70000 that is nothing anyone wants on their farm. Anyone that says a asp works good does not have may rocks, they suck.
yeah the asp is opening when there is no stones. Worked fine for lentils at a setting of 90%. But went on to barley and ended up turning it down all the way to 10% and it would still open 1-2 times per quarter mile swath (big heavy 30ft with zero lumps and laying as perfect as you can get cereal swath to lay and this field has ZERO ROCKS). The one thing I noticed even when doing the lentils was whenever the door opened for nothing it was always the top sensor that set it off and when ever there actually was a rock it was the bottom sensor that set it off. Cam setting on the feeder drum is at 3 and yes the feederchain is tight and not hitting the floor.
Oh and thanks bob123 for the info in the other thread ill be sure to use it if can get this asp to work right, I should be able to use it at atleast 70%-90% in all crops.
Discussion Starter #6
Same problem as ron. Perfect when straight cutting but picking up barley swaths is beyond terrible. Non stop phantom opening.
Probably checked but make sure there are no bent slats which may cause noise as well. The ASP is not a good system and too many stones pass through and wreck concaves, rotor covers, rasp bars and chopper region.
Downfall with my DSP is that it is tied to the separator and not to the feeder! It works great until you plug the rock beater. I must rig something up to reverse the drum.
My most effective unplugging tools are a battery powered reciprocating saw, a jackall, a block of wood to set the jackall on and a 2-3/8" cap to hold the wrench on the drum pulley so it can't come off. When tight you can't budge by hand - thus the jackall and block of wood. When I have time I am going to put a winch on and tie it up under the platform somewhere so I can reverse easier using power and weld something onto the end to grab on to the rotor wrench!
Moral of the story is you don't want to plug it! It is a dirty job and still requires pulling kochia weed out from underneath. The reciprocating saw is my best friend to cut threw the wads and help me pull out material while choking in the kochia dust!
I am done combining and only plugged beater twice and took out 2 concave shear bolts due to light crop. I don't want to talk about last year!
can you turn off the top sensor in the monitor or unplug it? mine has never said top sensor, always the bottom, not sure if it was modified by PO though, but works for me. Im sure I get a few false dumps still, but in our mostly rock free conditions I actually quite like it. I feel that asp uses much less power and therefore fuel, and in 2 years I have never, not a single time plugged the feederhouse, even in the very tough conditions last year. I would say no it is not perfect, but then again neither where the other brands I was driving alongside. so if rocks are going to get through anyway, Id rather use less fuel to do it.
ASP is the worst rock protection system on the planet. Pretty sure it's the nephew of one the founding parents of the company that invented it as to the reason why it wasn't discarded from NH many many years ago.
I have had both ASP and DSP. Best bet as previously suggested is to trade it off....
Actually I talked to the dealer this morning they told me that the top sensor was actually eliminated on most cr combines (except this one) and replaced with a new asp setup so it only works off the bottom sensor. new setup costs about $1200 and only the dealer can uninstall the old and install the new apparently.
Hmm so its an actual software update needed? Have you looked at the feeder tab in the arrow-diamond catagory? Otherwise for parts you could check combine world, they're parting out a couple 9X0 machines, I've gotten a few batches of parts shipped out to manitoba for less then half of dealer asking price. You could see what they think of reprogramming used parts but I'm guessing they'd prefer to sell ya some new stuff.
No its not only software, they would also have to replace the asp module on the side of feederhouse. The tech said by the time its said and done with eliminating the top sensor that it should remove most of bugs the asp has. As I said he told me the top senor in the feederhouse is where these combines had most of their troubles when they were new so most were changed out under some NH program back in the day. I gonna go with new stuff, used electronic stuff doesn't really interest me since you never know what little problems you might inherit with it.
Switched from a 9070 to a 10.90 this year. I would give almost anything to get away from the DSP. The electronic trap is not an option for the 10.90. I had my 9070 for 9 years and put more rocks through this machine than I did all the years with my 9070 put together. I don't have large rocks but lots of 3-4" ones. They seem to carry through with the swath, smash up in the rotors and end up in the grain tank. Even my truckers were asking what I was doing. They said it sounded horrible in the auger going into the bin. I hate the DSP. If you think your electronic trap is falsing too much, check your feeder chain. May be too loose or have a bent slat banging the sounding board. Be careful what you wish for with the DSP. The time you lose reversing and closing your trap, is nothing compared to a demolished rotor.
I have a polymer harvest service chain in mine, maybe that gives less false trips? Maybe also work on having less rocks get to that point, roll, make sure your header isn't digging dirt, float is light enough to ride over rocks, ECT. It's amazing what a nicely set header will do. Watched all season as rocks sticking halfway to 3/4 way out got nicely road over with no issues with a fd70. Don't angle the header farther forward then you need, i tipped my whole feederfaceplate back a couple more numbers. Make sure your pickup wheels are set right. I would guess my trap opened less then once per 100 acres. Case combine did alot more dollars in rock damage then the nh. Grass isn't always greener on the other side
1 - 16 of 16 Posts
