1 - 9 of 9 Posts
Hi I have a agco RT 120 that has a fault code D136. It still moves until it gets hot then it wont shift. Need a little help here.
the code indicates some trouble with the clutch pedal ....
unfortunately it says 'go to dealer'
fault code 136 is power management controller, power direction ....
isn't the newer stuff great fun!
Discussion Starter #5
crazy thing is i have the service manual for it (RT 100/120/135/150 Quadrashift). but the fault codes and clutch sections are missing got everything else.
These newer tractors are nice but a pain to work on.
if it helps the fault codes were found on
they also have fault codes for others as well ..
Discussion Starter #7
man that is an awesome place. but i got to ask, challenger codes are same as the agco?
it came up on a search for agco ... mind you i think several makes share the same ecm, including massey
1 - 9 of 9 Posts
