Updated tree plant on github AgOpenGPS_Dev.
Here is the code for triggering in position.cs
Code://tree spacing if (vehicle.treeSpacing != 0 && section[0].isSectionOn) treeSpacingCounter += (distanceCurrentStepFix*100); //keep the distance below spacing if (treeSpacingCounter > vehicle.treeSpacing && vehicle.treeSpacing != 0) { if (treeTrigger == 0) treeTrigger = 1; else treeTrigger = 0; while (treeSpacingCounter > vehicle.treeSpacing) treeSpacingCounter -= vehicle.treeSpacing; }
I’ve taken a while and took some online courses and done some sample programs. The C# is close enough to working with the Arduino that I’m finding it easy to work with. Haven’t gotten into the other areas yet.
I have attempted to make your code more dumby readable. If any of my comments are out of line please let me know.
All said and done I think I need to look for where treeTrigger = 1 is being passed to the ardduino and lastly triggering the relay. I’m on to that search next. Any hints will be appreciated!!
------------------------------ code xplination??? -----------------------------------------
Vehicle.treeSpacing vaue is set in the tree settings area
From there as the code executes and we fall into the section that tests for:
if (vehicle.treeSpacing not equal to 0 and section[0] (section 0 (we can only have 1 section set)) .isSectionOn ( test that the section is on)) treeSpacingCounter += (increment higher)
(If this first statement is true then the next in is exicued)
If treeSpacingCounter is grater than vehicle.treeSpacing and vehicle.treeSpacingis is not equal to 0
if (treeTrigger == (is equal to) 0) treeTrigger = 1 (set treeTriger to 1)
if the statement above is false
else treeTrigger = (set treeTrigger to ) 0;
while (treeSpacingCounter > (is grater than) vehicle.treeSpacing) treeSpacingCounter -=(minus) vehicle.treeSpacing;
(do the above loop until the above line returns a true value)
