Wilger tips are typically the drift reduction tips for AIM systems.
You can't use air induction drift reduction tips with AIM, as there isn't a constant flow of air going into the little air port into the tip.
The Wilger tips have a different technology, but gives the same kind of drift reduction results as air induction tips. Wilger makes 4 series of tips, 3 of which have drift reduction.
To make it easy to look into it:
ER (standard flat fan) - no drift reduction, so higher drift
SR (flat fan with drift reduction) - cuts down drift ~50% from ER. Still keeps smaller droplets for better coverage
MR (flat fan w/ drift reduction) - cuts down drift ~30% from the SR (so ~75-80% from ER). Droplets are getting to be ~coarse, but still give good coverage
DR (flat fan w/ drift reduction) cuts down drift ~20-25% from MR (so ~85-90% from ER). Droplets get coarse pretty quick with larger tip sizes (-05 tip size and up).
For Saskatchewan, you'd probably be looking at an SR or MR series tip.
If you do end up needing help picking tips, let me know and I can give you a hand working through the whole thought-process with AIM.
Also, if you had like 45 minutes, maybe watch the webinar Case IH/Capstan and Wilger put together reviewing and answering questions about AIM.
https://archive.org/details/SprayingTechWebinar
