Think I just found the potential answer from a previous post!
What lots of people don't realize is that with no back pressure (no product being applied) the fans don't reach full speed. So when you're sitting in the yard testing the fan speed it's not gonna be what it is when you're in the field seeding
Were you able to get the fan up high enough?
Same issue on my 3315 cart Versatile tractor is having a hard time pushing the fan right to the max.
Hyd oil temp does seem to affect it colder oil is slower for some reason.
I never found the fan speed increased much with product going through.
Honestly I think its the fan motor ezee on uses because the tractor has no trouble exceeding the max fan when its hooked to the Morris cart with the same crary fan assembly only difference is Morris used a different fan motor.
I even went through the Ezee on air tank hyd plumbing and took out some 1/2 inch fitting restrictions and bumped all the hyd up to 3/4'' on the fan circuit thinking maybe a hydraulic restriction, zero improvement.
