You guys that have run sectional control on your drills; how much does it actually reduce overlap? Currently my acres seed out about 10-12% higher than the acres that are actually there with a 54ft drill without section control and using autosteer. On the sprayer with section control I see around 3-5% overlap, but I like to error on the side of caution and the inside of headlands tend to get a bit more of a double spray. With seeding you have good visual site of your headlands and travel speed is much slower, so I assume the headland overlap with section control can be quite minimal if properly set up on the monitor.
Is it a realistic expectation to see seeding overlap in that 3-5% range with sectional control? I presume section control overlap reductions will be a function of the length of the sections and thus should be similar among mfg's using same section size. I have a new Bourgault drill coming and sectional control is something that I've been eagerly awaiting, but it is the only reason I'm going with a 7000 series tank instead of the 6000 series, to which there is a large price premium. I just want to make sure I can pencil out if the cost savings from reduced overlap to justify the higher cost of the 7000 series tank.
