you might also check to see if everything is sealed up good drain whole etc. i use duck tape if necessary If everything isn;t sealed up good it will not generate enough vacuum to spin it fast enough My alarm will go off put it usually takes about a 20 plus wind at the right direction to make the alarm sound....
