Actually the A. Seed down here is all over the board, but as a whole I think its well below average, I also hear through the grapevine that Canadian crop is pretty light this year. There were allot of leafcutter bee problems for some reason, and no one can really drag up a good reason for it. Also the Alkali's emerged really late, and the bug pressure was insane this year.
Anyway back to the bine's, we have blanked off 6 of the 9 concave slots on the 9660STS, we are running all small wire concaves and the last concave has every 3rd wire pulled. Also we are running a fixed airfoil chaffer, we tried the adjustable finger and it puts way too much seed out the back. This is also what the other STS in the valley did so you might want to pickup one of those. Deere doesn't make one so you have to go aftermarket. Harvest services LTD up in canada seems to be the only people that have them since A&I bought out loewen. We are running a punched hole screen under the airfoil, if you order one from Deere be ready to do some work on it. There build quality has gone way down on the fixed hole screens since your 9610.
As for settings, the bullet can be quite aggressive if you close it clear down. I run between 0 and 5 on the concave, about 800 on the rotor speed, and between 800 and 850 on the air. In good and dry defoliated seed I can run between 2.2 and 2.8 mph with a 25' head. One word of caution though when you get into heavy green hay the rotor does make some strange noises that the conventional machines don't. Anyway sorry about the long post, if I can help you in anyway let me know.
