I'm rebuilding my shaker system to hopefully give it longevity. I've replaced the shaker shaft, bearings, drive hub and clutch sprockets, cams and bearings, pivot shafts and needle bearings, bushings and new grade 8 bolts.
My Jensales manual didnt have any information on the shaker system so I stopped at my dealer and they let me look in their service manual. The case 1680 manual doesn't have anything on the cleaning system. I looked at a 2388 manual and it has a 9030 section on the cleaning system so I photocopied it to get me close.
They have never heard of the aligning tool, the next case dealer is 2 hours one way so I'm wondering about aligning it the hard way.
I started with digital calipers and adjusted the shaker shaft fore and aft to the nearest chassis flange (within 0.1 mm). I then went in the back and used the rear arm pivot bolt as a reference instead of a sheetmetal reference (I figured the pivot point for the system would be better to square to). I have the shaker and pivot shafts all within 1.0 mm of each other at the rearmost pivot point.
The factory manual shows aligning with a tape measure and I'm sure I've done the best job possible without the OTC tool but I'm nervous about doing this again near the end of harvest. Anybody have experience doing this the hard way?
Thanks
Thanks
