Re: Anyone ever put tracks from a quadtrac on a co
At the factory, I was told they take 20 HP per track just to move. In extremely soft ground, a wheel will take more than that.
The tracks on the 8120/9120 have a different mounting bracket than what the QuadTrac has, plus they have a final drive so that road speeds will be the same on a tracked and wheeled combine without needing to change the gearing in the transmission. The belt is probably identical, but the mounting brackets are different.
I know this question has been asked before. I'm sure its possible if you spent some time fabricating what you need, but I've never heard of anyone doing it.
-Lance
