Working on my cih 5240 with elect problem. For rev solenoids not getting power.
Can hear for, rev and latch relays click when shuttle switch is moved. tried swapping them around to see if one was bad, nothing. have continuity from solenoids back to their respective relays. have power at both fuses and from 10a fuse up to terminal 30 on latch relay. how to do relays work? I dont know enough about them to know were power should go from there.
Other oddities: neutral light comes on even though everything is in neutral and wont go out. recently replaced the dashboard beeper which should go off when the shuttle is moved with the park brake is engaged, but that isnt working neither.
guess my first question is where should 12v go once it gets to the 3B relay? or maybe someone had this problem before?
