Post in the Gleaner section and you will get more response!
What kinda bph were you getting? What machine and head?I only had 400 acers of wheat, but it was heavy straw 75 bu. that had to be cut abought a foot of the ground. It has great power and performed flawlesly. I have said it before, get rid of all reverse bars, made the machine come alive after that, with way less rotor loss.
Hi Redline, interested to know if you have the Cummins QSC with CAPS in your R65, what HP have you now got and what chip have you used? I have remapped our 2003 QSC to 300hp through Cummins, and under our crops we are always HP limited and mainly running in 90-100% load, with hand always ready to pull back on hydro handle, pushing large amounts of straw with a 25ft 8200. Fuel usage is similar to yours under these engine loads.850 bushel average? I hope thats because the guts need shined up, I can achieve those kind of numbers with my 65 pretty easily. Ive peaked at 1600 bushel at times and that was in 50bpa wheat using 13-15 gallon an hour @ 100% engine load with a 25' stripper header. I have some 80-90 bushel fields that I have yet to get the machine into. The engine is chipped, but still shouldnt be able to compete with the 8's. Maybe its the stripper header that gives me such an advantage.
Redline, my son drove it until the last 20 acres and didn't push it at all. I don't no how accurate the monitor is, never calibrated. I do no that if we could have cut higher like normal that would have made a huge difference. I did cut higher for just a bit and could run almost 6 mph, but leaving to many heads. I think when it gets shined up in corn and put the sweeps in, it will be ready for soy's. Only pu 30 sep. hours on it, so it can't be shined up yet. The bottom line is We really like the machine so far. Can't wait for the corn to get ready in a couple of weeks. Looks to be an exellent crop.850 bushel average? I hope thats because the guts need shined up, I can achieve those kind of numbers with my 65 pretty easily. Ive peaked at 1600 bushel at times and that was in 50bpa wheat using 13-15 gallon an hour @ 100% engine load with a 25' stripper header. I have some 80-90 bushel fields that I have yet to get the machine into. The engine is chipped, but still shouldnt be able to compete with the 8's. Maybe its the stripper header that gives me such an advantage.
I have a sisu in my R, stock is rated @ 300, with my chip its at 390. Although I've never had it dyno'd I believe the chip. I see it in the power monitor. 60% engine load on the "hot" tune is 90-100% in stock mode. My fuel consumption is down dramatically. I do have a chip in my mx285 that does have the caps pump you are talking about. Ive put 300 hours on it since I installed the chip. 0 problems with it or the engine/fuel system since I installed it. But its lowered my fuel bill by at least 20% in the 2 years Ive had it.Hi Redline, interested to know if you have the Cummins QSC with CAPS in your R65, what HP have you now got and what chip have you used?
Your breaking it in the right way, I didnt intend to come off as critical of your machine. Enjoy it, its going to be a monster when you get to pushing it come fall harvest. Take it easy on it though because ill be shopping for a used one in a few years.Redline, my son drove it until the last 20 acres and didn't push it at all. I don't no how accurate the monitor is. Only pu 30 sep. hours on it, so it can't be shined up yet.
