Thinking about getting a 16”x104’ swing auger. My MFWD tractor is only 160 hp which is too small. Looked at trading up to larger MFWD or buying an old articulated 4wd for running the auger.
Anyone running an older articulated 4wd and what are the pro/con and would you do it again. Looks like external controls could be plumbed on for the starting and pto.
Not sure if tractor width would be a problem or not, thinking about getting a rodonno xtend to replace the swing auger.
Will the articulation joint wander back and forth while parked and screw things up?
Or just forget the idea and spend the fortune to upgrade to a 250-300 hp MFWD?
