I recently installed ATI Tracks on my S680.
I am looking for the correct "tire" code for these tracks as well as the correct address to enter it in on the CAB controller for the S Series combine.
Thanks for the help!
I imagine they still do it this way
They used to just go by mm rolling radius, so less will read less proportionally, compare with GPS, adjust until speed readings dance on each side of each other, sometimes marginally less, sometimes marginally more.
Been too long to remember the address.:(
If they don't do it that way now I've just wasted a minute of your life and I'm sorry.;)
Found the answer. CAB 130. It is a seven digit code. First three numbers are the front tire code, last four digits are the rear tire code. Code for the ATI is approximately 724 for the first three digits and then whatever the rear tire code is after.
