I'm looking at buying a used J&M 875 grain cart that has a hydraulic kit on it. I would be pulling it with a 9180 case tractor (no PTO). My 9180 has an atom jet hydraulic kit already on it that I use for the air drill so thought it would be a good match.
My question is can I run the hydraulic motor on the cart with just the atom jet system or do I still need to use two hydraulics? Most places I read says that you always use 2 sets of tractor hydraulics to run the hydraulic motor (this is how the hoses on the 875 cart are currently set up). I believe my Atom Jet kit is 40 gallons per minute flow.
TIA
TIA
