Hi everyone!
Just bought a 2009 60ft DBS 300-D and was wondering what everyones thoughts on setting it up for heavy clays & bloody big granite rocks!?
From my research & looking at what I think could possibly be some weak points, these are my ideas to make this an even more accurate seeding set up.
-30mm closer plates double bolt to prevent breaking off.
-Change presswheels to new "V" type.
-Change bottom of fert tube to the old shorter model with finger holder to
prevent tube from blocking.
- Add Raycol air diffusers to prevent seed bounce.
- Change to shorter 5" knifes. Think they will be better for seed placement.
Shouldn't leave a deep slot for seed to fall down. Hoping plant roots & moving
to tramlines will help with hard pan??
- Seeding Canola- Raise digging depth from 4" to 3" and slow down to help with
seed placement??
What do you think, any other ideas?
What pressure does everyone set the tynes at?
Any thought on coulters? The flat bar the discs pivot on looks like they would be a weak point bending?
Cheers guys
seed placement??
Cheers guys
