Hey. I got a problem with '98 lexion 460.
Just as I finished wheat harvest, my auto contour cylinders quit working. Talked to a few mechanics and figured the solenoids and hub magnats went bad.
After I swapped them out, the cylinders don't move at all. Had the mechanic out today to look at it and after taking everything apart and checking for broken springs blockage in the lines, they still don't move.
Has anyone had this problem before?
Ty
It does have the manual switch on the left side and I've cleaned everything out with air pressure and let parts soak in the parts washer too.
Don, it doesn't have a 3position switch. It's just a rocker switch in the cab that either works one side or the other.
I have ordered a new valve body for the solenoid on the valve block so I hope to have it fixed by tomorrow afternoon.
