Hi guys
Our 10yo Autofarm RTK system which works off our two base stations is beginning to show it's age and I'm starting to have an issue our dealer believes is with our roof array, or most likely the two white dome antennas attached to the dish on each side. What is happening is that when I turn around, it shifts me across 1-2inches, but will then correct itself when I turn around and head in the original direction, but will keep shifting everytime the tractor does a 180 degree turn.
We switched the left and right dish around last year and re-calibrated the screen, however we're back at square-one now.
Our dealer in Australia is quoting $1000 each (or $3000 each new) for second-hand antennas which are likely as old as ours, so I'm investigating potentially fitting a L1/L2 antenna from Aliexpress (I'll put some links below for some that I think might be okay, although will need some modifications to our dishes to attach them).
I've been trying to research our particular antenna (AeroAntenna AT2775-83W-TNCF-000-RG-39-NM), but the closest I've come is the AT2775-81, which I can only assume is the same capacity/components but a different enclosure. See details below:
AT2775-81.pdf
I tested 11.55V coming out of the antenna wire, so any replacement will need to be able to manage this voltage.
My question is, will other much cheaper antennas do the same job provided it can handle the voltage, L1/L2 GPS, the gain is the same etc? Or is this even the issue, or is there something else I could try? Any help appreciated.
Here is one I have found on Aliexpress:
BEITIAN high quality GLONASS BDS GALILEO GPS antenna
AT2775-81.pdf
