And splice in Trimble's 63076 Cable...no thanks.breaking out the serial pins on the NAV controller.
Working with EZG-500, and if I read the TEALEAVES correctly, EZG's AUX port's cable(s) is wired back to NAV II via 62609 & 62754 cables (not verified yet). On 62609 cable, there appears to be an USB port in pic below. Would this be the access means for using Autopilot Toolbox II software on a laptop hooked to an USB to Serial Adapter Cable?It’s just a USB to rs242 like Guy1000 said.
Next week I plan to see a CASE tech on a related topic (flashing a NAV II for an update), but I suspect that USB port is used for that software program. Maybe only a USB-to-USB cable is needed. Logically, a service port would have been provided. All I found from Trimble was it was not for getting config/field data, which is done on EZG's backsideYou would have to
From Trimble's statement, "NMEA output is turned off from the Autopilot system," and from Sealevel's statement, " Easily connect your computer’s USB port to any RS-232 serial peripheral," I must conclude the DB9 end on Sealevel's cable plugs into backside of EZG's display.hard serial port- No such definition I can find, but I assume a DB9 to DB9 connection
USB serial adapter- Trimble indicates what they mean by buying that Sealevel cable
See first sentenceI thought you were trying to connect to the NAV?
Okay. I misunderstood what you were trying to do.Trimble offered two different software programs, one for flashing firmware, and one for configuring/calibration. The later one will be used. I understand AG Express will flash them for some $80. I plan to talk to a CASE tech Tuesday, and see if he can flash the NAV unit itself there, and see if he knows what that USB port on the cable was used for. I'm just wanting to use software for calibration...mainly a Roll calibration over a distance. Via EZG's display, its a joke...need installer software to do it right.
Sealevel's cable has same RX/TX/GND pinout as EZG-500's DB9 port, and Trimble suggested this cable. It uses an authentic FTDI ICs. See Note below in pic....I suspect some dealers screwed the firmware update with sub-grade USB/RS232 cables.
See first sentence
AUTOPILOT AUTOMATED STEERING SYSTEM TROUBLESHOOTING GUIDE
Version 4.00
Revision A
September 2016
nav controller...harness that has a rs232 port on it.
305 has a back seat full of wiring (USED ON IMPLEMENT), I'll have to take a look...but here are the cables used, 62609 & 62754 cables showing all ends, and I don't see a RS232 port available.NAV II wiring harness...rs232 port
Has a RS232 port on backside. Hooking a laptop to it with USB/RS232 cable should not cause an issue...either the software will communicate, or it won't. Keep in mind this display RS232 port can be used with AG252/262/372, and these AG receivers are "talking" in RS-232 "language."EZG-500 Display
CASE tech had no idea what it is for, but he was not around then. I will attempt to ask someone else. Here's a diagram below. 2&3 wires on USB port would not be used for serial communications...needs three wires...Rx/Tx/Gnd.Update: 62609 cable with USB port
USB is its own protocol(the plug has 5v, -s, +s, gnd) you do not run RS232 over a usb cable you only run USB(a usb cable is very specialized compared to RS232 where it doesn’t matter) as they are two completely different animals. More than likely that USB port either goes to a usb to CAN or RS232 adapter or it goes to dedicated pins on the display(I never seen a display with usb on the main plug, so this is less likely).305 has a back seat full of wiring (USED ON IMPLEMENT), I'll have to take a look...but here are the cables used, 62609 & 62754 cables showing all ends, and I don't see a RS232 port available.
Service techs with each new install had to configure/calibrate, so its highly unlikely these techs had to hack wires.
"There was a series of DirecTv receivers that had a USB port where you could plug in a USB to RS-232 adapter in order to give that receiver a standard RS-232 serial port...This was useful (back in the days before TiVo or on Demand viewing) to control which programs to record (unattended) on your computer for later playback."USB is its own protocol(the plug has 5v, -s, +s, gnd) you do not run RS232 over a usb cable you only run USB(a usb cable is very specialized compared to RS232 where it doesn’t matter) as they are two completely different animals.
Diagram shows two wires....not fourUSB(a usb cable is very specialized
My point stands. In your example it most likely uses a usb to rs232 adapter that contains a FTDI or microcontroller. They are two completely different protocols that would fry stuff if you tried and connect them. I also found a complete wiring diagram and all 4 usb pins are connected. Surprisingly enough they do have dedicated pins on the main plug. The usb may or may not be used for communication with a computer(would have to connect it to a computer and see if it works) or it could be used for data logging with a usb flash drive."There was a series of DirecTv receivers that had a USB port where you could plug in a USB to RS-232 adapter in order to give that receiver a standard RS-232 serial port...This was useful (back in the days before TiVo or on Demand viewing) to control which programs to record (unattended) on your computer for later playback."
Type A USB
Pin 1 is Bus Power (+5V originally limited to 500mA)
Pin 2 is D+
Pin 3 is D-
Pin 4 is Ground
Trimble said somewhere in one doc I've seen, not for an USB stick to obtain config/field-data...usage has not been explained. I plan to talk to an old timer tech tomorrow, if I can catch him in time....[USB] dedicated pins
