anybody here sucesfully installed rowsense on an older header so he could run the autosteer.
don`t have RTK on the combine like I had on the planter so figured installed rowsense on it.
is it hard to do and what were the cost.
or is it even possible?
First off what display are you running? 2600 or 2630? The kit for the 843's are easy to install. You will need a rowsense activation which is $2600 and the kit itself. If I remember right the 2600 you will need SF2 or the price for the activation is higher.
Here you go you will need both kits plus the activation.
PF90757 AutoTrac RowSense Retrofit Kit - Corn Head
Required for AutoTrac RowSense to operate on 90 Series Corn Head (Model Year
2002 and newer) with 30 In. or 75 cm row spacing. AutoTrac RowSense Mechanical
Feelers not included; order appropriate mechanical feeler kit separately. $665
PF90697 AutoTrac RowSense Mechanical Feelers (30 In. or 75 cm Row Spacing)
For use with 30 In. or 75 cm row spacing on John Deere 90 Series or 600 Series Corn head - $1023
