Re: Axial-flow Repair/Maintenance Tips thread
On the later 2388 model's remove the air filter and inside of the air filter housing you'll see i believe 8 small holes on the right side, make sure there clean. They fill up easily with fodder and other material and the machine will run crappy. If need be remove whole assembly and clean. Tip use drainage tile cap to plug intake tube then u can just use compressed air to blow out holes w/o fear of blowing dust into motor. This applies to the newer machines (2003+) that have the silver air screen on the right side. This may also apply to earlier machines, but that is unknown.
Purchase small round blind spot mirror and fasten to right side railing outside door on the right side of the cab. Then u can see the window in the extensions to see when full instead of trusting that stupid warning light.
