1 - 2 of 2 Posts
Trying to get the axle hub off my T9.670 (blue Stieger) so I can get inner wheel of the triples off. We have been alternating between torquing the three jacking bolts and belting the taper ring with a 10lb sledge for an hour with zero result. Had these off 2 years ago but now wont budge. Any advice appreciated.
Discussion Starter #2
No replies but I have solved the problem so will post here for others in the future. Noticed even though the book says use 3 bolts there are 6 threaded holes. Changed our approach by taking the 3 jacking bolts out then cleaning and oiling all 6 holes. Then used 6 jacking bolts and tightening all alternatively with a 3/4 rattle gun. No need to do any hammering as the bolts turn incrementaly each time and as long as you use a crisscross pattern it eventually pops off.
1 - 2 of 2 Posts
