AZS-800 is a new type roller-driven pellet machine for professional manufacture of wood pellets. This vertical double ring-die pellet mill overcomes the disadvantages of flat die pellet machine and traditional ring die pellet press, that is to say AZS-800 pellet machine has the advantages of flat die pellet machine and the ring die pellet mill at the same time. And it is professionally designed for making biomass pellets from various biomass materials including wood chips, straw, bamboo shavings, peanut shells, bagasse and so on, so it is the first choice for new starters who want to start a biomass pellets making business.
Advantages of AZS-800 Vertical Ring Die Pellet Machine
1. Feeding vertically and rotating rollers solves the problem of raw material accumulation of both flat die pellet machine and ring die pellet machine.
2. There is cooling device in the vertical ring die pellet machine, so it solves the problem of heat dissipation of traditional ring die pellet machine.
