AZSP-360D is diesel powered R-type pellet mill. R-type pellet mill is called rotating roller type pellet machine where the rollers turn on the top of a stationary die. This pellet machine is geared lower about 100-150 RPM. This pellet mill can pelletize almost all kinds of materials, such as sawdust, wood chips, grasses, alfalfa, corn stalks, cotton stalks, wheat straws, newspapers, leaves, hay, grains and so on. It makes the harder material like wood material into pellets more quickly and easily than D-type pellet machine.
Features of AZSP-360D Diesel Flat Die Pellet Machine
1. It applies long diameter rollers, which makes the machine have a larger capacity than D-type pellet machine, high molding rate. The wood pellets made by this machine have good shape, good durability, high hardness and high density.
2. Both the rollers and the flat die have passed wear-resistant process. The two side of the flat die is exchangeable, which extends the lifespan of the machine.
3. All bearings adopt the leak proof structure in order to prevent dust and improve the working environment.
More details:Rotating Roller Diesel Flat Die Pellet Machine/Biomass Pellet Machine
Contact: [email protected]
